Biga
Near Miss Racing #96
- Joined
- Dec 8, 2015
- Location
- Houston, TX
- Moto(s)
- 250 Ninja "A"
R3
600 GSXR
TS 185
150 Scooter
97cc D. Bug
- Name
- Rod
I think 10 V means you have a bed cell in the battery.
Mad
Resting fully charged 12 volt batteries are around 12.8-12.9 volts, and flat dead ones are at 12.0 volts, so 12.4 volts on a resting battery means it's about 50% charged.
A healthy 12 volt motorcycle battery should maintain a range from 9.5 - 10.5 volts under the load for a good 30 seconds straight. If the battery begins to hold and then steadily drops in voltage, there is a problem. If the voltage instantly drops to 0 volts, that is also a problem. We call this the open cell. On a new battery, this can be a result of manufacturing flaws, but it also may be caused by sulfate crystal buildup.
https://www.batterystuff.com/blog/how-to-tell-if-your-battery-is-bad.html
