ST Guy
Well-known member
JimE makes a good point that I've neglected to mention. On many bikes, the wiring going to the bulbs and back is barely adequate, resulting in voltage drops by the time the juice gets to the bulbs. Buy rewiring and bypassing the stock wiring entirely, significant gains can often be made. You can still use the stock switches and relays, but you tap the power directly off the battery and use additional relays if necessary.
I've never understood why bike manufacturers still can't adequately wire things like headlight circuits and also can't design charging systems that fail if you look at them sideways. It ain't rocket science.
