NorCalBusa
Member #294
You can also skip this entire resister exercise and just get an LED purposed flasher.
What's that! I already bought the mirrors/flush mounts though =(
Look at post #8:What's that! I already bought the mirrors/flush mounts though =(
Legally, you're allowed up to a 2-blink/sec. rate. Faster than that and you may get a fix-it ticket. Personally, I think the higher rates attract more attention and is more visible. Here's a solid-state flasher relay that doesn't care about circuit-resistance:
http://www.grote.com/product.php?product_number=44120
http://www.cyclegear.com/eng/product/led_signal_relay/web1006869
http://www.ledlight.com/electronic-led-flasher-el13a2.aspx
A lot of modern bikes have solid-state relays as opposed to old-fashioned bi-metaliic/thermal relays. Check out how yours responds 1st. I know on my CBR, that the blink-rate remains constant regardless of whether I attach LED or incandescent filament bulbs.
Also, I just tapped into my existing wire harness for the blinkers and good to go. No issues at all....
You want to remove some insulation from the turn-signal wires that have the connector. Maybe 1" from the connector.This is exactly what I want to do!! That looks awesome =)
How do I "tap" into the existing wire harness for the blinkers? If you can show me a picture of the wiring and how you did did that that'd be awesome!
If I am understanding what you guys are saying correctly, if I just solder the mirror wires to the flush mount wires, that means I would never be able to take off the mirrors right(cause the mirror and flush mount wires wouldn't be attached by a connector)? If that's the case, I probably want to go to the connector route you suggested.
Also, what do I do about the third wire(I think the ground wire)? That's the wire that makes the LED's in the flush mounts and Mirrors act as running lights correct?
I think, (if I am using the terms correctly), I want to put a connector on the led mirror's wires, and attach both the led mirror's wire's connector and flush mount's wire's connector to the "terminal" that's already on my bike?
But I still don't know what to do with the ground wire. Do I need to attach a third wire (which should act as a grounding wire) with a connector to the flush mount and led mirror?
Sorry for all the questions! This is my first time soldering anything or working with circuits in my life! I just want to make sure that I do this right the first time! But it is fun learning! =]
Thanks for all the replies!
It is a 3 pin connector on the bike, G being ground. Orange and light blue are your running lights. O/W and Lb/W are your turn signals. It looks like the connectors on the flushmounts are 2 pin, so go ahead and cut those off. You can either buy 2 OEM style connectors, or cut the ones off of your OEM signals leaving a few inches of wire, and solder the flushmounts and mirror wires to it. Blk to G, Y to O/W on the left, Y to Lb/W on the right. Isolate and insulate the O and Bl running light wires.
Orange/White is one wire. Its for the left side turn indicator. On the right there will be a Light blue/white wire. The yellows on your new indicators go to those wires on each respective sides. Blacks go to the green ground. The 3rd wire is unused, you will be ditching the running lights. You should cut half way between the light and the connector, so both pieces are reusable to some extent. Again, using the new connectors Danno linked instead of clipping yours off would be optimal, but there is a $20 minimum on that website. If you go that route, buy extra terminals for the connectors in case you mess up soldering on them. Also, go buy a few feet of wire and cut it up and practice soldering since you never have before.
