Alan_Hepburn
Well-known member
We have a Ring doorbell on our house and it works quite adequately. We noticed that they also have a Mailbox Sensor that will alert us when the mailbox is opened, so we figured we'd try it out. So, I'm having a problem getting it to work: we have our internet/wifi router in the back corner of our house, about 30 feet from the front door, where we have a Ring Bridge, and the Ring Doorbell. From the front door to the mailbox is about 200 feet. Part of the setup procedure involves being at the doorbell and using the app, through a wifi connection, to activate the system. The problem being that the wifi signal does not reach the mailbox from about 230 feet away. It's designed to use the Amazon Neighborhood network, but that doesn't exist out here in the sticks so I'm forced to use the Ring Bridge option. Allegedly the Sensor has about 1000 feet range from the Bridge, but it needs a wifi signal to set it up.
I'm wondering if I can temporarily take the mailbox sensor into the house, and set it up there, then move it back to the mailbox? I can't find a "Contact Us" option on the Ring website so I thought I'd ask you fine folke here, who seem to know everything!
