And here you can see how I clearanced the top so I could just mount the petcock plate in the bottom piece....
So, while I'm waiting for the gas cap to be machined, I decided to get to work on the venting system. Some of you may be thinking, "Wait a minute, isn't that an aftermarket gas cap and isn't it vented already?"
Here's the deal. It is vented but it's vented in such a way that I'd need to carve out the gas cap mounting area from the stock tank since the vent actually vents to an internal 'under the cap' vent that, on stock bikes, then runs to the infamous charcol filter. I didn't want the added weight from all that steel...So what I need to do here is go back to the stock tank, cut it open and pilfer the venting system. In our application, we'll just run the vent out the back of the tank. I could have stuck a dirt bike vent tube on the top of the tank but I'm not a fan of that look. This is stealthy and looks better, IMHO, even if it does weigh a few ozs more. Here, I'm trial fitting it, bending the tubing so I can bond part of it to the side of the tank and route it out the rear of the tank.
I have to make a small extender, but that's simple enough - I just sleeve it with a section of the gas cap overflow tube from the stock set up. We'll live without that overflow set up. Zoran will just have to be a little more careful when filling the tank...
I'll bond the vent 'cap' (that silver cylinder) to the tank just behind the gas cap, then bond the tube to the side of the tank. I'll bond around the tube where it exits the rear of the tank. Three attachement points will be plenty strong.
So, this is all we can do until I get the cap back. I want to mount it, then add the vent system. After that, all we have to do is bond the top and bottom to seal this bad boy up. Then it's on to the mounting sysyem.
Hope you're enjoying this final set of steps. We're about a week away from finishing this project!
