Dani i don't want to discourage you but,... you mentioned Praying. these machines speak German. you should learn to swear at them in their native tongue, because they'll just ignore you if you don't.
Das ist gutNo updates yet, but Thabks to the great answers I think I have a good game plan.
1) general tune up ,Replace spark plug, check valve clearance, fresh gas , check fuel lines and fuel filter. Someone told me that this year needs a valve adjustment in the first 2500 miles if I read my service manual.
Pray
2) possibly replace the throttle sensor, possibly The oxygen sensor.
Cross fingers
3) replace the missing washer with the 3 holes and/ or remove the PC5
4)Scout for an impossible to find stock pipe
Cross toes
That's the perfect bike up here.I would ditch the PCV and use TuneEcu to load a different map.
Looks like there’s one on the list here that had the Leo Vince, as well as one that mentions the stalling issue resolved:
https://tuneecu.net/AustrianCustomMapList.html
I have the cable and setup to load if you want to borrow.
Don't randomly replace parts without testing them first to verity with numbers that they are indeed bad. Otherwise, you're replacing perfectly good parts with brand-new perfectly good parts and nothing will change. I've seen people replace injectors, fuel-pumps, fuel-hoses, fuel-rails, FPRs, O2-sensors, TPS, MAP/MAF sensors, when the only thing they needed to do was adjust TPS with multimeter.2) possibly replace the throttle sensor, possibly The oxygen sensor.
Cross fingers
Cross toes
My money is on the lack of valve adjustment, i.e. one of the exhaust valves is too tight.
That was also my mechanics guess so let’s see if you are right.My money is on the lack of valve adjustment, i.e. one of the exhaust valves is too tight.
*me*
Intermittent=fuel or electrical not mechanical.
I like the PC removal as step 1. Fast easy and free.
Is there any reason that you are not listening to the professional diagnosis rather than soliciting wild ass guesses from the peanut gallery?
*me*
Is there any consequence to doing this ? Ie. Could it potentially make it worse or throw off the timing elsewhere ?
No, Hank. The problem is that even the “professionals “ weren’t sure about what step to take and the initial remove the PC pos and return to stock pipe wasn’t possible due to no stock pipe being available. Not even my very talented professional mechanic was 100% sure of what move to make first without the Dyno diagnostic coming back the way it did .
I have found that when one throws an issue out to the Barf, one often scores a home run. Sure some are bloopers but most of this is gold considering that the internet is fragmented with glimpses of all of this. At least someone in the future can benefit as well , get it all laid out in one place.
