So the BIGGEST “ hindsight is 20/20” lesson that I have learned here :
1) only buy a KTM from a KTM expert ( like A Conan or a Stan23) who will have a wealth of info and a meticulous bike.
OR,
2) Go Directly to a KTM specialist and do not waste your time or efforts on anything less. $1500 and a lot of time and energy could have been saved.
Appointment booked for MACH 1.
Hiya Dani... I don't have the answer for you this time but I have a few
suggestions to add in hindsight that might multiply your pleasure and divide
your grief when buying used next time...
Used bikes are full of unknowns... there are 3 things I'd want known before
buying from anyone expert or not...
Compression Test
Request or perform a compression test... if the engine shows factory
compression then break in was complete right which gives evidence
that the piston ring seal is good...
Idle Check...
Start the engine at let it gain operating temp... take the idle
adjustment and begin lowering the rpms... you're noting the lowest
rpm the bike will run... if the engine ticks over near 500 rpm or
less... there's a lot of things right about the internal condition...
things like compression and tune up... buyers may negotiate the
price shrewdly based on this simple idle test...
Steering Stops...
Check the steering stops for crash damage... this will signal a fall and
even which side sustained the damage... you can replace everything but
the steering stops will still give it away...
Troubleshoot tips...
Battery...
Start with the battery for it's the weakest link in the whole system... To
determine the condition of an Maintenance Free battery give it a
refreshing charge... wait 30 minutes... measure terminal voltage...
12.8 or higher is a good battery...
12.0 to 12.8 is a insufficient charge... recharge...
12.0 or lower... battery unserviceable...
I'd would not begin troubleshooting unless the battery's starting
voltage is greater than 12.8 volts and the charging system is steady at
the prescribe values specified in the offical shop manual... drop a few
volts and notice how the ignition and fuel injection begin to error
enough were riders complain about rough running...
Noises...
To troubleshoot an internal noise the first step is to establish the
rate at which it occurs... is the noise in time with the camshaft or
crankshaft??? camshafts rotate 1/2 the speed of the crankshaft...
possible source of camshaft speed noises are shim and bucket
clearances... loose cam bearing blocks... broken valve springs...
possible source of crankshaft speed noises are a scuffed piston...
stuck piston ring... rod bearings...
To pin point the exact location of the noise hold a long tip screw driver or a
length of garden hose up to your ear and probe the suspected area...
