$800?
I'm wondering what this bike is supposed to be? Or what it was in it's last life. Do you have photos of what it should look like?
Remember the name, the Night Rider.....
Those are Dunstall fairings. I had one on a Kawasaki triple I bought in the 70s. I thought they were cool at the time, but they were kind of hokey.
$800?
Don't knock it.I was raised on that movie
Looks like you have polished the valve seats too. Im sure you know they will have to be at the least lapped to match valve face. That material is/should be very hard, surprised you took the polisher to them.
I'm surprised anyone polishes the CC or ports at all. We haven't done that in years. All fluff as far as I'm concerned. But you are right on the money Jim, he will need to lap that correctly, that is if any seat is left.![]()
No kidding. When I was running the 5 axis at the Top Fuel shop, they spiraled the tool out, from the inside of the port, maybe 1/8 inch, almost scallops, from as deep in the port as the tool would reach, about a 6 inch long tool reaching in there with a 1/2 ball (like a lolipop), all the way to the outside edge, and profiled them all the way out, and shipped them like that. Not a deep scallop, but enough to feel and see clearly. And these were first done on a flow bench, then digitized, so every one they did, was exactly the same. The machine would flip them over to the chamber side, and the blend would be nearly perfect.
So cylinder temps and floating valves can't be tested with your alcohol test. I'm not bashing you for trying, I'm just saying some of the methods you are using so far are a little unorthodox, that's all. But wtf do I know.
I don't see the harm in taking apart a running motor to replace gaskets, cleaning stuff, or "polishing."
If it ain't broke....
I'm basically "resealing" the engine. I don't see the harm in taking apart a running motor to replace gaskets, cleaning stuff, or "polishing". Anyway, once its all done. I'm sure I will have broken several things and fixed several things. I am also sure it'll be just fine.
