All I know is we were all stuck shooting 1/200, f/9ish, iso100. I know jack about lighting, dunno what else i can tell you
Why only 1/80th for these? Limitations of the triggers you're using?
if your talking about this photo![]()
then change your aperture...and probably use 1/80th or so...the photographer is far enough from the subject and DOF wont be a problem...
i can get away with 1/80th iso 100 f4 with that kinda setting...even with f5.6...
maybe flash at 1/2 power or so...
I don't see how shooting at 1/80th would solve the overexposure problem. We were shooting around 200 shutter speed and was stuck around f9-f11. If we shot any slower shutter speed than that it would overexpose. Shoot any numerically lower f stop and it would also over expose. These were not my lights and it was my first time using them also. We had ISO set at 100. I would like to try to figure out why we had this issue hopefully we can try this again with not be so limited on time. I remember Ian mentioned he turned the power output of the lights quite a bit. Not sure how low he turned it down but I ended up shooting the rest of the day with just the modeling light.
Oh, FYI, I didn't have the flash trigger, that was all ambient, what you're seeing on the brolly is the modelling light...
This has been something I've been trying to figure out. I feel like I'm so close to understanding strobe lighting, but there is still some mystery. My education on the topic is an amalgamation of bits and pieces from this thread, from strobist.com, from browsing strobist setups on Flickr and whatever I happen to find on Google.
I don't really have a method, as you describe above, to setup and tweak exposure. I just play around with it until it looks right. Even a blind horse finds water sometimes...
What I would LIKE to learn is how to set up everything /manually/. No TTL, no iTTL, nothing. The strobist guy hooked me when he suggested learning it this way and they you'll never have to worry about this system or that system.
Can you give an example? For instance, you're indoors, you set your aperture to, say, 5.6 and take a shot. Shutter speed is 1/200 or whatever... OK. Got it. Now you switch over to 1/200 and 5.6 [M]anual mode, yes? Why is this step necessary? Why not just go 1/200 and 1/250 every time and whatever aperture you want, and just adjust the flash power for the correct exposure?
Bueller? Bueller? Anyone?
Can you give an example? For instance, you're indoors, you set your aperture to, say, 5.6 and take a shot. Shutter speed is 1/200 or whatever... OK. Got it. Now you switch over to 1/200 and 5.6 [M]anual mode, yes? Why is this step necessary? Why not just go 1/200 and 1/250 every time and whatever aperture you want, and just adjust the flash power for the correct exposure?![]()
That's pretty much what I do in a controlled environment. If I'm not mixing with ambient light, I set the shutter to 1/250th, the aperture to what I want or need to make the photo look how I want, and adjust flash power as necessary.
In the field, blending with ambient, and shooting on the run, the gloves come off and I'll do whatever I need to give me an image. Often this means setting aperture priority, dialing the meter to -1EV to underexpose the background a bit, and using my ISO to control how much of an impact the remote flashes have on my image. Weird and unconventional, but it effectively gives me the ability to control my flash power in an instant from the camera, without affecting ambient.
I guess you can skip the step, but it's easy to end up lost in the settings if you don't already have a handle on things. This step gives you a nice baseline. I suppose you can do it your way too, but what if 1/200th of a sec is way off and you end up needing more light than you have in order to get the type of shot that you want?
The method I described is what I use to blend the the strobe lighting with the ambient. I've been working hard to build this skill more than any other. I figure that anyone can shotgun things to the point when the lighting looks good. But, not everyone can blend things to the point where you can't tell that a flash was used. Not all of your shoots are going to be in a nice studio. You will eventually work outside. When you're there, you will need to blend with the ambient.
I am starting to look back at some of the pics I took when I first started and can see how much better they would be if I knew how to blend flash with the ambient.
for example:
Too much flash:
Almost perfect amount of flash:
Unfortunately, these were just happy accidents for me, but they kind of show you what I'm trying to get when I take pics.
I think I may have to play around with it a bit. I'm not sure if I am asking the right questions...
I didn't think shutter speed had any effect on the intensity of the flash?
When we talk about adjusting shutter speed, we're only talking about /adjustments to ambient light/, yes? Or no?
Same with ISO?
Keep in mind, I have no method right now.
Each time I break out my flash it's a clusterfuck^H^H^H^H^H^H^H^H^H^H education.
I think I see what you're saying.
Similar to Cycle61's comment... We're talking about balancing ambient light. And that is why we adjust the shutter speed and ISO, no?
Conversely, the only way to "blow out"/over-expose a subject, is to set the power too high on one's flash. Correct?
Ummmm....crap. I've lost the direction we were going here.
Flash exposure is affected by:
Flash power
Flash to subject distance
Aperture
ISO
Ambient exposure is affected by:
Shutter speed
Aperture
ISO
The places where these lists don't overlap is where you get to control the two sources separately.Knowing how to do each separately, or both together, instinctively, is how you make the magic.
