saizai
My Ninja died (AGAIN!) - help please?
'02 Ninja 250, ~6100 mi.
Last night, I was driving from a friend's home to Berkeley campus, mostly downhill. Suddenly, the bike died - while I was riding it.
It happened just after a stoplight, and wasn't instant - more like a very very fast version of the battery dying. Only had ~180 miles on tank; usual reserve is @ 205. Switched it to reserve anyway.
I roll-started it successfully twice down that hill, but it died again.
Roll-started it again, and had it running for about a minute; when I let it rev down to idle (i.e. released throttle), it died.
Roll-started it again, same deal.
Got it to a gas station. Checked all the fluids and fuses - all OK. Oil slightly low, but within normal range.
Got a jump start from a van. Bike started up again fine. I adjusted the idle speed to be ~2krpm, and just let it sit in neutral idling, so as to let the battery charge. About 10 minutes in, it spontaneously died - rpms dipped immediately before.
Disconnected the running lights that I'd installed 2-3 days prior. They had been running fine for those couple days without incident, but I thought that maybe the running light lead - which I was feeding off of the left hand horn wire (the constant-on when in ON one) - might be doing a slow drain of the battery somehow, or overloading the system.
(Other modification I made was to solder in two extra brake lights put in the previously-empty side pods. That was a couple weeks ago, and worked without any issue on a 1300 mi road trip.)
Got another jump start. Bike idled fine for ~15 minutes. Adjusted idle speed again. Decided it looked like it was working, and rode off.
Bike died two blocks away. :-/
I rolled / walked / coasted it to an unregulated-parking area in downtown Berkeley, and parked it there, which is where it's now sitting (I hope).
I have records indicating a battery was bought 6/17/04 @ Interstate Batteries - a YTX7L-BS. Don't know how many miles it had at the time, or whether a new one has been bought since (probably not).
I haven't been having any other electrical or mechanical issues at all.
So, three questions:
1. What is likely to be wrong with the bike, and how can that hypothesis be tested?
2. What can I do to fix it myself - given I have minimal tools (socket set, drill, fuses, etc., but no electrical testers or etc) and mechanical skill?
3. Bids on how much you'd charge me to come fix it?
Thanks!
Thanks!
