ThumperX
Well-known member
- Joined
- Aug 26, 2007
- Location
- Off Elk Mtn
- Moto(s)
- Different strokes
Big Bore and little bore Thumpers
- BARF perks
- AMA #: 2817058
Dang. You all, why is everyone up?
Depending on the Digital Analog Converter it may sound better using optical digital audio out or digital coax to bypass the internal DAC of the old CD player.Looks like I'm looking up that RCA cable to hook the croaking CD changer up to the amp ??!
Nice.75 inch Sony Bravia 7. The wife wanted to go bigger![]()
I recently got an Nvidia Shield TV pro for streaming. It supports 4k content, however my AV receiver is like 20 years old so I doubt it supports 4k over HDMINice.
Try these calibration setting from the well respected RTings site for a more optimal picture.
SDR = settings for 1080i/720p content on cable and most streaming and 1080p Bluray players and streaming devices like Roku etc.
HDR = setting for 4k content like Bluray 4k players and some streaming channels like Disney+ assuming you have a 4k streaming device hooked up to the TV using a 4k HDMI cable.
I assume you are sending sound from the TV from the Nvidia content to you receiver using an optical digital audio cable so as long as the Nvidia is hooked up using a 4k HDMI you should get 4k on your TV with streaming services that provide it.I recently got an Nvidia Shield TV pro for streaming. It supports 4k content, however my AV receiver is like 20 years old so I doubt it supports 4k over HDMI
No, I'm just using HDMI from the streaming device to the receiver, and another from the receiver to the TV.I assume you are sending sound from the TV from the Nvidia content to you receiver using an optical digital audio cable so as long as the Nvidia is hooked up using a 4k HDMI you should get 4k on your TV with streaming services that provide it.
Well, that's fine if none of your streaming sources are 4k.No, I'm just using HDMI from the streaming device to the receiver, and another from the receiver to the TV.
Are you going to try adding four speaker Atmos?I may give that a shot! I'm definitely planning on upgrading my receiver in the not too distant future.
I'm not trying to do anything crazy. I've got a pair of tower speakers that are plenty good for usAre you going to try adding four speaker Atmos?
You should be concerned if your wife says she wants to go bigger.75 inch Sony Bravia 7. The wife wanted to go bigger![]()
it looks like I own only 1 optical cable and I can see it sticking out of the TV already, so I'm guessing I'm using it for TV-audio to the amp. (BTW that digital-IN says "Assignable..")Depending on the Digital Analog Converter it may sound better using optical digital audio out or digital coax to bypass the internal DAC of the old CD player.
That's how i hook up CD players as they are often older with less sophisticated DAC's than modern receivers/integrated amps.
