Sunday morning I took a good look at the profile in the morning and decided I wasn't happy with the seat angle. It was just slightly too high in the back. It reminded be a bit of the streetfighter crazy that hit the UK a few years back where everyone jacked up the tails really high. It wasn't that bad, but I decided it needed to come down just a bit.
20210822_104240 by
andbike, on Flickr
Here are a few more angles. Note, the tail is barely in place for the photos.
20210822_104315 by
andbike, on Flickr
20210822_104407 by
andbike, on Flickr
Back at the shop, I've cut off the rear support and re-made the stubby little support tubes. This time they're about 1/4" shorter.
20210822_124903 by
andbike, on Flickr
And back on with the cross support.
20210822_133915 by
andbike, on Flickr
20210822_133933 by
andbike, on Flickr
I would spend the remainder of Sunday, starting on the rear sub-frame fixture. This is a process of building a structure that will pick-up all of the mounting points from the sub-frame so it can be easily duplicated later. Its a bunch of rough cut tubing and tabs. Along the way I check for symmetry. The most important aspect of building the fixture is to be sure the original sub-frame and subsequent sub-frames can be removed from the fixture. So some though goes into how everything is positioned. Oh, and I also need to keep in mind welding access. So just a few things to think about along the way.
This is an odd little set up, but it worked really well for drilling two 90 degree tabs with holes at equal height.
20210822_142648 by
andbike, on Flickr
Now it just adding tubes and tabs...
20210822_155130 by
andbike, on Flickr
20210822_155508 by
andbike, on Flickr
20210822_172422 by
andbike, on Flickr
Its not finished, but go most of the front portion completed.
20210822_183241 by
andbike, on Flickr
20210822_183646 by
andbike, on Flickr
Back home at the end of the day I mock-up the seat and tail. It probably doesn't look any different in the photo, but I like the slightly decreased angle much better! It was a good call to make the change. I'm very happy with how its looking.
20210822_193913 by
andbike, on Flickr
Stay tuned for a possible mid-week trivia question
arty
