afm199
Well-known member
It's a cross product. The dot is there because the units are composed of distance and force and you need some way to tell the factors of the units apart, but it doesn't really denote multiplication in the sense of a multiplicative product of some numbers. Torque is equivalent to a composition of a norm of the amount of motion and the amount of stuff that's in motion. Which means that it's equivalent to energy, which is obvious if you pay attention to the fact that the composition of the unit is represented pretty much like the playskool formula for work.
Teal deer: Don't think about it too much. Torque isn't power but they transform into each other because math. Torque is how much stuff you can do, power is how quickly you can do stuff.
I had this discussion once about the WTC on Quora once. The guy was insisting that the incident was demolition. I urged him to calculate the amount of energy in 300 tons of jet fuel, as it is SEVEN times the amount of energy in TNT of the same weight. He just couldn't get it. He insisted that the TNT had much more energy, that it would have been necessary for TNT to bring the building down. I said, no, one gram of oil has seven times the calories that one gram of TNT has. The only difference is adding TIME to the equation. The TNT can combust extremely quickly, the oil much more slowly. The end result is the same, the oil puts out seven times the energy the TNT does. And the WTC output from the jet fuel alone was over a kiloton of TNT equivalent.
