A.... I was just razzing the OP about changing out the SD on his bike....
and then someone had to go and get all holier than thou *cough*cough* ^^^ *cough*cough* so I was "forced" into defending my razz....
geez
Your argument above about how it can be used to settle inappropriately set suspension... leads me to say why not save the money on a sd and get your suspension set right (i know 400 fo an sd 40 for a suspension setup...) hmm I know where I spent my money!!!
I have been in situations where I wished I had an sd... wheeling out of turn 9 or turn 5 at thill.... always makes me pucker up... your coming down into a freakin turn, almost sets you instantly up for a tank slapper
Yes I am using my tires as a crutch...
... the bt002r/s is a dedicated track tire???? just like the ntech211s right??? i get it now... or how about I run a street tire on the track (ding ding ding... I DO)
so to summarize if you routinely get tankslappers than you should go buy a sd.... do not get your suspension fixed (which forks travel in a linear (vertical) manner and tank slappers in a linear (horizontal) manner so I am not sure how related the two truly are...) and do not try and figure out why YOU get so many tankslappers... that way you never actually correct the original problem... because the sd will correct the problem for you....
now do you see my argument about sds??? probably not because you are right and i am wrong...
