How much traction do those grates across the Bay Bridge have?
[youtube]kHGrGOWLB5g[/youtube]
This is why all the people who say "ABS is a crutch" are wrong. There is no conceivable way that any sane rider would be trying that normally...unless you knew that you had an electronic safety that would make it effectively impossible for you to crash while doing that sort of test. I was pulling the rear wheel off the ground on the brakes there, and you can hear the tire howl as it approaches the limits of traction on the grate.
I never actually even cycled the ABS doing this testing - there was enough traction available that it wasn't needed. But ABS allows me to prove that in an incredibly low risk fashion.
Also, this goes double for traction control. When you can spin up the rear in a very low risk environment, you much more rapidly get comfortable with the limits of rear wheel traction.
ABS and TC will allow you to exploit the limits of performance in a way that no rider with out it can. You can whine about scotts dampers and the riding experience, but at the end of the day, if you don't have it, not only are you going slower, you have less access to the performance of your bike, meaning situations that would be completely safe and reasonable for an ABS and TC equipped bike could be completely unsafe for a bike without it.
If you want stats:
Our new electronic overlords are here and they are good, get on board, start demanding it as standard on bikes, and let's save some lives.
