i've used the 400 5.6 a bit and it works great. also it weighs nothing in comparison to the bigger guys
Yes, and yes.
Actually, since they only have a single copy, it's probably the same one I used last August.
It's sitting next to me at my desk right now. Awfully tempted to leave work and go shoot. Gotta wait a few more hours.![]()
Cool man!! thanks... my sister in law is having a civil ceremony coming up and was thinking about checking out some faster glass than the kit stuff i got right now... hmmmsss maybe i'll check out the 85 f/1.2??![]()
yea, i wish nikon made a 400 5.6... or a 400 4.0. i'll never be able to afford the 2.8 ;P
i dont own the canon 400 5.6, i've just used it a good amount
Unfortunately the D5000 doesn't have a commander mode.On my D90, I set the camera's built in flash to commander mode. Make sure the camera and the flash are on the same channel.
no need for a fast glass if you got a good flash...you will be shooting mostly a 5.6 to get good DOF anyways...
I might have to go like the PocketWizard way.
Transmitter on the hotshoe, receiver on the SB600 for off-cam flash.
Really lame in Nikon's part.
I was reading that if I got an SB800 flash I could control the SB600 to fire off-cam, but that's soooo g'damn stupid as the SB800 costs more than the D5000.
Nikon FAIL.
Stoopid little flash mount thumbscrews
Always getting lost, and I hate buying new cold shoes just for the screw.
I've started tapping them out to 4mm and using standard hardware.![]()
A couple of shots with the new 35mm f/1.8 recommended by JoeThe 50mm uses an older design for the focus mechanism, which requires a focusing motor in the body and a mechanical interface to drive the elements in the lens. Your D5000 does not have this motor built-in, and therefore will not autofocus with the 50/1.8. The 35/1.8 uses a newer setup, with the focus motor built in to the lens.
The 35mm will also give you a somewhat wider (and IMO more usable) angle of view for normal everyday shooting. I've used mine quite a bit for shooting in low-light situations and it performs quite well. It's not extremely sharp wide open (at f/1.8) but is still much better than the kit lenses.
Both are very good quality for their modest price tags, but I think the 35mm will probably be a better choice for you.![]()
