Ducky_Fresh
Treasure Hunter
Lighter
Narrower
Better Tires
Narrower
Better Tires
Lighter
Narrower
Better Tires
everyone pretty much answered in complicated and uncomplicated ways, but if i can just be really simple here, i mean, REALLY SIMPLE,
it's the fucking tires.
Let's try this. First the tires are amazing. Second, they don't even work until they are HOT. So HOT that some riders can not get them hot. In order to get them hot you need to BRAKE HARD. That's why you see the front guys and midpackers on the front wheel with the rear in the air in most corners. That is new MotoGP style. Hard braking and trail braking gets the tires hot and they work really well. The bikes do NOT handle well, they are hard to turn. Spies says they turn like a truck.
Short version. Great tires, great riders, great brakes. Must get tires HOT. This requires big balls braking skills. IIRC leg out braking and Bridgestones are synonymous. Nobody used leg out braking before Stones. So basically the best riders in the world can get the tires hot enough to work well.
First time I've heard that one.Let's try this. First the tires are amazing. Second, they don't even work until they are HOT. So HOT that some riders can not get them hot. In order to get them hot you need to BRAKE HARD. That's why you see the front guys and midpackers on the front wheel with the rear in the air in most corners. That is new MotoGP style. Hard braking and trail braking gets the tires hot and they work really well. The bikes do NOT handle well, they are hard to turn. Spies says they turn like a truck.
Also, the leg out braking thing has nothing to do with how easy or hard it is to brake. Rossi just started doing it and everyone followed suit. It's a style thing not a function thing.
I thought it had to do with balance under heavy braking?
Turn like a truck? Rear in the air? What are you talking about? Aside from neither of these things being true, they don't even make sense. Why spend millions to develop a bike that has the exact opposite of the properties that a race bike should have? Why build something that is worse than your production bike?
Better stability at high corner speed, but you know that. Stoner seems to whip those trucks around pretty good.See Ben Spies interview in Road racing world, read it, and get back to me. He says the bikes are MUCH harder to ride than WSB, the 4" front rim and long wheel base make it turn like a truck. That's Ben Spies, not me.
Second, this generation of GP bikes are ridden superhard on the brakes with the rear tire off the ground on hard braking constantly. Do you actually watch the races? This is a new style as is leg out, and NOBODY wastes time with style at that level unless it has FUNCTION, there is no advantage in wasting energy. Why do you think it happens so much? To look good?![]()
I thought you were suppose to squeeze the tank under braking, no? Saw that in Racer's Corner once.
You're not comparing lap times of GP bikes after they ditched qualifiers, are you?
