The goal on Saturday was very simple... make the steering head bearing cups round. Simple goal, but not so simple process.
To start, I needed a way to securely hold the frames while taking a VERY light cut with a boring bar without making the cup diameter too large and scrapping the frames in the process. The cups started out round and the correct size for the bearings to press fit, however after all of the welding the cups have distorted slightly and need a "skim cut" to clean up and get round again.
Step one was to tighten up the gibs on the mill. I don't want anything moving during this operation. Step two was to make a holding clamp...
20211023_151224 by
andbike, on Flickr
20211023_160501 by
andbike, on Flickr
20211023_163108 by
andbike, on Flickr
The next step was to get the frames securely clamped. Then with the boring bar disengaged (so it could spin freely) the frame was carefully positioned so that the boring bar would just cut the high spots on the inside diameter. When I was satisfied that I had the frames in optimal position the boring bar was reengaged and a cut was made.
20211023_175348 by
andbike, on Flickr
20211023_175358 by
andbike, on Flickr
The bores look nice, and if you look close you can see where the cutter removed material and where it didn't. Like I said, it was a VERY slight amount of material to remove.
20211023_192222 by
andbike, on Flickr
20211023_192325 by
andbike, on Flickr
20211023_192340 by
andbike, on Flickr
Final check was made with some fancy tools that only come out for special occasions
arty
20211023_140247 by
andbike, on Flickr
On Sunday it was back to welding. The rear of the frames needed some welds finished, so just wanted to make some progress there. In particular, the rear hoop that the shock mounts to need to be welded all the way around where it joins the main frame tubes in preparation for gussets to be added (hopefully this coming weekend).
I'm not the greatest welder, but these will have to do.
20211024_183136 by
andbike, on Flickr
20211024_183219 by
andbike, on Flickr
20211024_183338 by
andbike, on Flickr
Two frames getting very close to completion (third frame is still tacked only and will be completed later).
20211024_183122 by
andbike, on Flickr
