Frame Maker
- Joined
- May 8, 2011
- Location
- Livermore
- Moto(s)
- sportbikes, dirtbikes, and some odd bikes that I've built myself.
- Name
- Julian
Those are fantastic! Are they for stock YPVS porting? What peak RPM? It may be an optical illusion but the header / diffuser section seems quite long.
Cheers.
These are good questions which I don't have complete answers for, so I'll try to explain the criteria I gave to Brian...
I few years ago I purchased two sets of pipes from Brian one set was for an RZ350 with stock (unmodified) engine, but significant chassis mods. I also ordered a similar set for a similarly modified chassis, but with an RZ250 engine. The pipes for the RZ250 were slightly shorter and have slightly smaller stinger diameter, otherwise very similar.
The 350 specific pipes have been mounted to my prototype frame with a stock engine (photo below). I've had very little time to fine tune the jetting, but I'm happy with the performance so far. They have LOTS of low to mid-range power which is exactly what I was looking to get for street use. That said, they don't rev as high as other pipes but Brian thinks that will improve with correct jetting.
Fast forward to the current batch of pipes, I had the same requirements for good low to mid-range performance for street riding, but try to improve the top end range a little. Brian and I discussed the goal a bit more and decided to copy the basic geometry of the slightly shorter 250 pipes, but open up the stinger diameter to work with the 350 engine. So that's what you see in the pictures. I have not tried them yet so can't say one way or the other how they work.
I will say that I have numerous sets of pipes that Brian has made and none are similar to the more well known brands of pipes that most people use. For example, he's built a few sets of pipes for my RZ250 and when I asked for a more top end performance. The first set he built will rev strong to well over 11k, maybe higher. It wasn't practical for street use so he re-made them and brought the top end peak down closer to 10K. Still peaky for street use, but that's what I had asked for. He has geometry that he likes to use and I trust his judgment. When I give him a request, he tries to builds to my criteria.
That probably doesn't answer you question very well, but time will reveal how well these new pipes perform.
20220417_163006 by andbike, on Flickr
