I went to Home Depot today and picked up one of the oil filled heater units to see if that might be a stop-gap solution to the hot room. Turned out it worked pretty well so, depending on just how cold it is, I may be able to get away without having to build an entire room inside the garage.
Once things we're warmed up a bit, I did the layup of the other 1/2 of the top mold.
One of the big challenges for me is waiting until everything has cured sufficiently before I start messing with it. I'm like a little kid who can't wait...I am getting better so I expect I'll leave this to sit for a couple days before I pop it out.
But once it's out, I'm set to make the plug parts using my splash mold! Here's where the 'important' work really begins as I narrow the tank and determine the final top-bottom interface design.
What I mean by that is I won't copy the stock shape that has the seam running down the side of the tank. I'm planning to eliminate that vertical seam so the top part will actually have a horizontal surface that the underside can bond to. It's a bit hard to describe - the pics will make it easy to see what I'm up to. Look for those in a future post. For now, here's the other half of the top splash mold in cure state.
Time invested to this point: ~ 10 hours. I'm happy with that.
