ThumperX
Well-known member
- Joined
- Aug 26, 2007
- Location
- Off Elk Mtn
- Moto(s)
- Different strokes
Big Bore and little bore Thumpers
- BARF perks
- AMA #: 2817058
Tires for YEP work? Meals and beverages provided.
Wow, guess we're all falling apart :sighWaiting for my turn in the mri machine.
What is the correct position for the presta Valve?Take it, fix it and ride it or sell it. Sounds like the soft brake probably needs to be bled, those small master cylinders can get air in pretty easy. I need to bleed mine as well, someday. The tires probably are tubeless and have sealant in them. Sealant has a fun side effect of sealing the valve too if the bike is stored with the presta or shrader valves in the wrong position. You can probably replace the valve with a new one or clean out the existing one. Chain and cogs might just need to be lubricated, rust isn't always a death sentence, and worst case they just wear faster and you eventually replace them anyway.
Tires oughta get me up there for a time or two. Once you're all healed up and I've replaced my helmet and fixed up my riding gear. I need to see if there is anywhere that can repair / patch holes in codura, seems a shame to toss the jacket over one big hole in in the shoulder.Tires for YEP work? Meals and beverages provided.
I think TWT knows someone that does repairs. You might just ask the folks at Johnson's Leathers if they can repair it.Tires oughta get me up there for a time or two. Once you're all healed up and I've replaced my helmet and fixed up my riding gear. I need to see if there is anywhere that can repair / patch holes in codura, seems a shame to toss the jacket over one big hole in in the shoulder.
Onder!Tires oughta get me up there for a time or two. Once you're all healed up and I've replaced my helmet and fixed up my riding gear. I need to see if there is anywhere that can repair / patch holes in codura, seems a shame to toss the jacket over one big hole in in the shoulder.
Pitbull still a thing?What do the cool kids do these days for rear stands?
If this is the shop that has been working on your car, I'm not sure I wanna deal with them You can certainly poke the presta, but that'll push the core into the tire so you'll still be stuck removing the tire. Fun side note, tubeless tires tend to end up almost glued to the rim because of the sealant. It's... not fun.There are these mechanics in the far out nether areas in town you don't like (the areas not the mechanics) but apparently some people go there
they're Irish
Should I poke my Presta valve hole with a nail ?
I actually took off the presta core and hooked the pump to the open stump... It didn't take air ...STUCK
IM THINK there's rubber protector tape over the hole actually
