ThumperX
Well-known member
- Joined
- Aug 26, 2007
- Location
- Off Elk Mtn
- Moto(s)
- Different strokes
Big Bore and little bore Thumpers
- BARF perks
- AMA #: 2817058
Hmm I should check, when I was dropping off for CityBike the address was more residential.
Yes there is a hose, the red hose attached to the side, visible in the video in this post:Leak could very well be at the brass fitting.
1) Obtain spray bottle with soapy water solution. 2) Run "unit" until tank is full. 3) Unplug "unit" from electrical power source. 4) Spray soapy water solution
around all pneumatic lines and fittings. 5) Check the pressure relief valve (make sure it opens and closes and seals) and also the hose coupler fitting.
Did the "unit" come with hose and male fitting that fits the hose coupler fitting?
We should get that for Kurosexi!
Probably a vestigial twin that finally learned morse code, "LET ME OUT, LET ME OUT".
The guy in the background wanted to get in on the fun too.lol bahahahah
isn't it too early for that type of thing in the morning?
